Report Preferences - Rebalance Dialog
This dialog is available from the Options / Report Preferences... menu command under any Report window.
This dialog page allows you to specify preferences on how Rebalance Reports are displayed. The following options are available:
Display Columns:
Choose which fields (columns) are displayed in the report.  See Rebalance Report for a description of each field.
See Also
Rebalance Report
Report Window
Report Filter Settings
Report Colors
Report Column Labels
Report Preferences Dialog
Fund Manager Home
