can I change info across multiple investments?
Postby joesmo » Fri Mar 02, 2012 12:53 pm
Thanks Mark,
The insight into the retrieve currency selection should make downloading my trades doable as manually setting new symbols once is defiantly doable.
I do have US and CAD in the same accounts but they are held in Canadian brokerages which do not offer the retrieve functionality and the transactions still have to be entered manually.
Yes I use sub portfolios for my US and CAD investments. Thanks.
joesmo
Postby joesmo » Fri Mar 02, 2012 1:51 pm
I just realized I never resolved the Currency issue on text import.
Here is the import string:
UD,SYMB,TRAN,ANUM,BNUM,CNUM,CURRENCY
The first two lines of my text file:
060803,FNMMF.X,BUY,0.950000,400.000000,57.00,USD
080122,FNMMF.X,SELL,0.000000,400.000000,-0.00,USD
Currency Settings:
Default Currency = DEF
Currency 2 = CAN
Currency 3 = USD
Currency 4-24 = ""
When I do a generic import the transaction currencies are set to DEF.
joesmo
Postby Mark » Fri Mar 02, 2012 2:06 pm
Hi joesmo,
That looks correct. I also just copied/pasted the data below into a test file, and set my currency settings as you've described, and then did a test import. It created a new investment correctly assigned to USD.
Could you maybe have some extra whitespace characters at the end of the line, so it is USD<space> that you aren't seeing? If not, please attach or email us the exact text file you are importing, and I can try importing your specific file.
You can also double check you don't have any extra whitespace character in the Currency Setting dialog where you've assigned the USD and CAD currency symbols.
Postby joesmo » Fri Mar 02, 2012 2:19 pm
Oops, I forgot to update the import file pointer(twice)!
Works fine like you said.
joesmo
Postby joesmo » Wed Mar 07, 2012 12:52 am
Having imported several more files using the generic transaction import function, I can say that there does appear to be an issue with the currency when importing transactions into an empty portfolio. The currency import only works if I create a dummy investment first and assign it the currency I want to import.
Regards,
Joel
joesmo
Postby Mark » Wed Mar 07, 2012 8:21 am
Hi Joel,
Can you provide me a sample import file and format string you're using to reproduce this problem?
Previous
