Program Hang on closing portfolio
Postby Mark » Mon Jan 20, 2020 4:23 pm
Hi Scott,
Thanks. Which sub-portfolio in that picture are you unable to close?
Postby sbfree » Tue Jan 21, 2020 6:16 am
Good Morning
I had tried to delete the one labeled DM 403b Schwab that was a sub of All Accounts. The DM 403b Schwab portfolio was linked as a sub in the DM Retirement portfolio as seen in the screenshot from the previous message. Deleting all the investments in DM 403b Schwab did not resolve the problem.
scott
sbfree
Postby Mark » Tue Jan 21, 2020 6:51 am
Hi Scott,
Were you able to delete DM 403b Schwab after un-linking the other sub that was pointing to it? I believe you were on one computer, but were going to confirm on a second computer?
I've tried reproducing this situation, but so far haven't been able to reproduce the problem.
Postby sbfree » Tue Jan 21, 2020 10:44 am
Haven't tried yet on the desktop that I normally use. Was successful on a laptop with a new install of FM and restoring files form desktop to it. Will get back after I get my backups in order. Distracted by prep work for preparing an IRS 1065.
scott
sbfree
Postby sbfree » Thu Jan 23, 2020 7:20 am
Hi Mark:
I deleted any portfolio that had linked subs. This let me delete the portfolios without value.
If you would like more explanation of how I had configured portfolios please let me know.
Scott
sbfree
Postby Mark » Thu Jan 23, 2020 9:31 am
Hi Scott,
Did you have to delete _all_ the link sub-portfolios before you were able to close that sub-portfolio? Or did you not try until you deleted all of them?
Postby sbfree » Thu Jan 23, 2020 10:02 am
I did NOT make an attempt until all the portfolios with linked subs were gone.
s
sbfree
Postby Mark » Thu Jan 23, 2020 10:03 am
Okay, thanks for the help/information.
Postby sbfree » Thu Jan 23, 2020 10:08 am
I have a backup from before closing the portfolios. If you would like, I would try and redact out the security information and account update access and forward a backup file. I would need some guidance on how to do that.
scott
sbfree
Postby Mark » Thu Jan 23, 2020 10:30 am
Hi Scott,
That would be great. Here is what you can do:
1) Make a backup of where you're at now, with things fixed, so you can get back there easily. Use "File / Backup...".
2) Restore from a .FMB file where the problem existed. Open up the "Properties..." of each sub-portfolio with account number information and delete it, and also the "Transaction Retrieve Settings..." username/password.
3) Use "File / Save Portfolio" and then "File / Backup...".
4) Verify the program still hangs if you close the sub-portfolio. If so, send us the *.FMB from step #3, along with the name of the problematic sub-portfolio, so we can reproduce the problem here.
5) Restore from the backup made in step #1.
Postby Mark » Tue Jan 28, 2020 9:40 am
Hi Scott,
Thanks for sending the test case *.FMB file. This is very helpful. I too am able to reproduce the problem using this data. We'll get it fixed for the next release.
Postby sbfree » Tue Jan 28, 2020 10:00 am
Glad to hear it and glad it is not a problem with my Win10 install. Was it the result of something I configured that was not an anticipated use?
s
sbfree
Postby Mark » Sun Feb 02, 2020 2:53 pm
Hi Scott,
Sorry for the delay in replying. It was a bug in the way we were closing sub-portfolios when linked subs were involved. It also required a certain configuration of the hierarchy to see this bug. We have fixed it for the next release.
Postby sbfree » Sun Feb 02, 2020 3:48 pm
Good to hear as an end user and as someone that's written some code, glad you found a fix so quickly. Thanks for the support.
scott
sbfree
Previous
