Sector Retrieval from morningstar.com options
Postby jb3 » Mon Aug 15, 2022 10:26 am
Great. Thanks, Mark. What is the file format that FM will recognize and read?
jb3
Postby Mark » Mon Aug 15, 2022 11:56 am
Hi jb3,
It is a CSV formatted file. If you open up the import dialog, and press Help it will show you the documentation, or you can view it online here:
https://www.fundmanagersoftware.com/hel ... t_cat.html
The import and export both use the same format, so you can first export, and then just modify the exported file before importing it.
Postby jb3 » Tue Aug 16, 2022 11:34 am
Got it. Thanks for your help and patience, Mark.
J
jb3
Previous
