Multicurrency
Postby rsabbah » Mon Feb 15, 2010 2:51 pm
I have diferent sub-portofolios in diferent currencies , I would like to visualise the master portofolio in a single report o and on a single default currency, how can I do this?
rsabbah
Postby Mark » Mon Feb 15, 2010 3:33 pm
Hi rsabbah,
Create your report at the sub-portfolio level above all your lower level sub-portfolios, and it will include everything. For example:
Code: Select all
Master Portfolio
  - Acct 1
  - Acct 2
  - Acct 3
Report at "Master Portfolio", and it will contain everything from the 3 accounts beneath it.
To view everything in a single, default currency, turn on "View / Exchange Rate Adjusted". You need to make sure and set up your currency conversion options under "Options / Currency Settings...". You might want to watch the multi-currency tutorial:
http://www.fundmanagersoftware.com/tuto ... video.html
Postby rsabbah » Tue Feb 16, 2010 11:14 am
rsabbah
