swissquote
Postby manageruser » Tue May 04, 2010 12:24 am
Hi Mark:
Since you are fixing up swissquote, I am trying to get the price for xag into fundmanager and it doesn't seem to work. Can this be fixed?
manageruser
Postby Mark » Tue May 04, 2010 9:25 am
Hi manageruser,
Thanks for pointing out this problem. We've just released version 418 which fixes this problem. Hopefully we can go more than 1 day without releasing another update...
Postby manageruser » Tue May 04, 2010 11:52 pm
Mark:
I just tried it and it seems to work. Thanks very much. Swissquote is actually worth the effort as they have quotes you don't normally find elsewhere.
manageruser
Postby manageruser » Wed May 05, 2010 1:36 am
Mark:
XAG works but no EU774 doesn't, which worked before the latest update.
Sorry.
manageruser
Postby Mark » Wed May 05, 2010 8:15 am
Hi manageruser,
I just tested retrieving EU774 from Swiss Quote, using module 418, and it retrieved properly. Is it still not working for you? Make sure to check in the Data Register under the "Prices" data type. Also, for this server, it is important to retrieve with the option:
Options / Internet Settings... / Proxy Server / Use Windows Settings
turn ON. If it still isn't working, please also check the investment's properties under "Investment Properties... / Internet Retrieve".
Postby manageruser » Sat May 22, 2010 4:31 am
Hi Mark:
Yes, it works if I change to "use windows settings" in proxy. However, normally I can use my normal proxy for the other quotes. Seems strange there is a problem only with this one.
manageruser
Postby Mark » Sat May 22, 2010 9:44 am
Hi manageruser,
Yes, this server is slightly unique. Some of the quotes require a redirection to a different URL, and FM only is capable of this with that "Use Windows Settings" option turned on.
