opening fund manager
Postby scottnewbie » Wed May 12, 2010 9:32 pm
When I open the program FM there are at least 100 screens that rapidly scroll across my screen. After all these screens flash by, the program opens with the screen that shows my Master Portfolio and all its subportfolios.
It seems as if every report I've ever requested is rapidly flashing across the screen prior to settling to the final screen.
Is this program behavior normal?
Scott
scottnewbie
Postby Mark » Thu May 13, 2010 7:52 am
Hi Scott,
These are indeed all reports you have created, and are saved as part of your portfolio. It is best to close a report once you are done with it. If you keep going to the "Reports" menu, you are creating a new report each time. If you've already created a report, you can switch to it under the "Window" menu, instead of creating a new one each time. For more help on this, and how to fix it, please read:
http://www.fundmanagersoftware.com/faq_ ... kering.php
