Simple Question about Saving Work.
Postby DavidJ » Thu Jul 15, 2010 12:56 pm
Hi!
I like to save my work after entering a few transactions, notes, or whatever, in case of a system crash, or anything similar.
After what kind of updates should I hit "Save Investments", and after which ones "Save Portfolio"?
I'm running v. 10.3 Personal.
David.
DavidJ
Postby Mark » Thu Jul 15, 2010 1:08 pm
Hi David,
Investments save your transaction and pricing data. They also save properties of your investments. Every investment is saved in its own *.dat file.
A portfolio file saves all your sub-portfolios, including their properties, and which investments they contain. The portfolio file also saves your workspace, like which windows you have open, and various preferences. Generally you only have one portfolio file, and this is the *.mm4 file.
So, whenever you modify any pricing/transaction data you would want to save your investments.
Postby DavidJ » Fri Jul 16, 2010 1:01 am
Thanks!
D.
DavidJ
