Investment Limit in Advisor Ed
Postby paulk » Fri Nov 05, 2010 8:22 am
Hi again Mark
so I know there is a 50,000 investment limit per portfolio in the Advisor edition. I have all my client subportfolios organized under a master portfolio (my RIA). Is the 50,000 limit for the total of all the posrtfolios or is it per sub portfolio?
paulk
Postby Mark » Fri Nov 05, 2010 8:30 am
Hi paulk,
The 50,000 limit is for the total of all sub-portfolios. Basically, you can only have this many investments open at once, no matter what sub-portfolio they are in. Are you concerned about hitting this limit?
Postby paulk » Fri Nov 05, 2010 9:31 am
I imagine I should be ok considering I have a relatively small RIA practice. I am sure there are others using the software who are more likely to hit the limit than I am and if they aren't concerned I suppose I shouldn;t be. It only struck me as worth asking because I never want to have to switch software again now that I've decided on using FM.
Thanks for your quick response and fine product.
paulk
