Cost Basis rules - Schwab download
Postby crawfordn » Wed Dec 08, 2010 1:12 pm
The new cost basis rules are resulting in Schwab including cost basis info in their download. I suspect it will be a separate file, so I may not need to worry about it. It will apparently reflect adjustments for things like bond amortizations as well. Have you had any contact with them or previews? They will have a capital gains treatment "tax optimizer" which looks a lot like your min gain treatment. Will there be a reconciliation possibilty for tax lots? I will have my costs on their system match those on FM by Jan. 1. Thanks for any edifyiing advice you might have. Best, Rick
crawfordn
Postby Mark » Wed Dec 08, 2010 1:21 pm
Hi Rick,
We haven't heard anything from Schwab. I just sent our contact there a question about this, so if I hear anything, I'll post the update here.
We did hear from TD Ameritrade about this, and they are changing their transaction file format, so it wouldn't be surprising if Schwab is doing the same thing.
Postby crawfordn » Wed Dec 08, 2010 1:32 pm
As usual, I'm one step behind you. I'll keep checking periodically. Thanks. Rick
crawfordn
Postby Mark » Wed Dec 08, 2010 2:24 pm
Hi Rick,
It seems Schwab will be making new files available starting Dec 15. You can read about the new files here:
http://www.schwabadvisorcenter.com/publ ... _tech.html
The existing files remain un-changed.
Postby paulk » Sat Dec 11, 2010 12:49 pm
Hi Mark
I didn't catch this topic earlier. So TD Ameritrade will be including a separate file to reflect what they are carrying as cost basis along with the TRN and POS files? Any plans on including a reconcile feature in FM to reconcile the cost?
paulk
Postby Mark » Sat Dec 11, 2010 1:09 pm
Hi paulk,
That would be a nice new feature. We can consider adding this into a future release. We don't have any real near term plans for adding it.
Postby paulk » Sun Dec 12, 2010 10:00 am
So this new TD dowload format will not change anything functionality-wise or reporting - wise in the program?
paulk
Postby Mark » Sun Dec 12, 2010 10:17 am
Hi paulk,
Yes, this is correct.
