display two pie charts?
Postby chancee » Thu Dec 09, 2010 9:02 pm
Can I display two pie charts next to each other in the top window for comparison purposes? If so, how? Thanks
chancee
Postby Mark » Fri Dec 10, 2010 7:52 am
Hi chancee,
Yes, you can do this. Create 2 graph windows, and put the desired pie chart in each one. Graph windows are independent from each other, so you can graph whatever you want in each one. To create a new graph window, use "Graphs / New Window...". To help you see both windows at the same time, use "Window / Tile Down" or one of the other window commands.
Postby chancee » Fri Dec 10, 2010 8:51 pm
Okay, perfect. What about the colors in the pie chart? Can I assign them to a specific asset? When comparing two asset allocation pie charts next to each other they represent different assets on each graph because of the differing percentages. Right now it looks like the colors are assigned based on percentages of the whole. Blue always going to the largest, etc. Can I make blue always be a certain asset like Large Cap? Thanks.
chancee
Postby Mark » Sat Dec 11, 2010 9:10 am
Hi chancee,
Good point... Unfortunately, this isn't adjustable. That would be a good option for us to add.
