Finished building a large portfolio. Saved it. Added info to individual investments. Probably closed Win 7 without closing FM first. Now I can't open the portfolio. What do I do?
Win 7 FM 10.8
Can't open portfolio
Hi Sinclair,
What specifically goes wrong when you try to open the portfolio? Do you get an error message, or just not see what you're expecting to see?
Hi Sinclair,
It sounds like you just may not have any windows open. Try using "View / Portfolio Editor" to open up the Portfolio Editor window, and see if you can see your sub-portfolios and investments okay. Your portfolio file (*.mm4) remembers what windows you have open, their position, etc. After you get whatever windows open you want (Portfolio Editor, Reports, or Graphs), select "File / Save Portfolio", so the next time you open this portfolio, all those same windows will be re-created just as they were when you last saved the portfolio. One possibility is that if you close all your open windows, and then exit Fund Manager while the "Options / Save Portfolio On Exit" option is turned on, then you are saving your portfolio with no open windows. It is not necessary to close all the windows before exiting Fund Manager.
Hi Sinclair,
Glad you got it working again. It sounds like maybe your windows were moved off your screen. If you run into this again, you can use the "Window" menu commands to put everything back to some nice defaults. For example, use "Window / Cascade".
Who is onlineUsers browsing this forum: No registered users and 24 guests |
