Portfilio Management
Postby johnreid » Sun Feb 17, 2008 11:10 am
When I began to enter my stocks, I thought I created separate portfolios under the Master Portfolio, using the Portfolio wizard. What I appear to have done is to create, under the Master Portfolio, a new Master Portfolio, say XXXXX; and all of the other sub portfolio's are under it, rather than under the real Master Portfolio. Mind you, the XXXXX portfolio is under the Master, in any event.
I can probably live with this, but I would like more control as to how I develop and shape my portfolio.
Now that I have this situation, how do I go about undoing it? If I have to remove the portfolio structure to redo it, I assume this will not destroy my data.
John Reid
johnreid
Postby Mark » Sun Feb 17, 2008 11:37 am
Hi John,
Fixing this is quite easy. Just use the "Portfolio Editor". You can drag/drop to move sub-portfolios wherever you want them. For help on doing this, please see the Portfolio Editor tutorial:
http://www.fundmanagersoftware.com/tutor_ports.html
and documentation:
http://www.fundmanagersoftware.com/help ... tedit.html
