Extremely small negative share fraction remaining?
Postby nagorak » Sat Feb 23, 2008 12:47 am
I recently sold an investment completely which should close it out, but the value is still being displayed as -1 cent. I believe the share value entered in Fund Manager might be barely off due to rounding, so it believes I now have a small negative share balance. Unfortunately, if that is the case, the share value is less than one thousandth (.001) of a share, so it is rounded down to nothing and I don't know how much to alter my final transaction to get rid of this negative balance.
nagorak
Postby Mark » Sat Feb 23, 2008 9:02 am
Hi nagorak,
You can adjust the number of significant digits displayed in the Data Register. Use "Options / Preferences... / Display" and turn up the number of significant share digits to 6. You can then view/edit your transactions, so that you own 0 shares out to 6 significant digits. This should correct the problem.
Postby nagorak » Mon Feb 25, 2008 7:10 am
Thanks for the help! 8)
nagorak
