Hello Mark,
Thanks for the reply on the omit weekend problem.
I see version 11 has no export function as you suggested to Elliot on 11 April. We had in previous versions of FM - is there any reason why it is missing in version 11.
I have e-mailed you the options I find under the FILE menu.
Regards.
