Hi Mark -
I read that v 11.xxx installs over v 10.xxx.
If that's correct, is there a way to run the two versions in parallel until I decide to go permanently to v 11.xxx?
THANKS!!
Test v 11.xx in parallel with v 10.xx
Hi fiscalis,
You can install v11 and v10 into separate directories, so you can run both of them. The only concern is that you don't want to save a portfolio file with v11 that stores an open graph or report type that is not available in v10, as you wouldn't be able to open that portfolio file in v10.
Who is onlineUsers browsing this forum: No registered users and 15 guests |
