Downloading Updates
Postby Ivan » Sat Apr 23, 2011 9:35 pm
Maybe I'm not remembering right, but when I have FM check for updates, didn't it offer to download and install them if one was available. I have 11.0. When I check for updates it informs me that 11.1 is available but does not offer the option of updating. Should I just download and manually install 11.1?
Ivan
Ivan
Postby StarBright2011 » Sun Apr 24, 2011 2:19 am
Ivan,
I had the same occur for me. Yes, I just downloaded the update and installed it manually.
Ernest
User avatar
StarBright2011
Postby Mark » Sun Apr 24, 2011 4:25 pm
Hello,
Only the quote and transaction modules can be updated automatically this way. New program versions (11.0, 11.1, etc) must be downloaded and installed from the download page:
http://www.fundmanagersoftware.com/download.html
