opening several memorized reports at one time.
Postby michael » Fri Jul 01, 2011 8:50 am
I'm using the same four memorized reports tiled across the screen very often.
Is there anyway to link the reports together so that they open together and display tiled across the screen?
Sorry if this is a "stupid" question.
Michael
michael
Postby Mark » Fri Jul 01, 2011 8:00 pm
Hi Michael,
Not a stupid question at all... You can do this with your portfolio file. Portfolio files remember all your open windows, and their position. Just open up all the 4 memorized reports, and position them as you want. Now, do "File / Save Portfolio". The next time you open this portfolio (which happens automatically the next time you start FM), all those same windows will be re-created just as they were when you last saved your portfolio file.
The option to recall reports is on by default, but you can check under "Options / Report Preferences... / General / Portfolios Store and Recall Reports".
