Using CrossOver to run FM on a MAC
Postby Maury56 » Mon Jul 11, 2011 7:14 pm
I am running FM on my MAC using CrossOver.
The program runs fine except that I am having trouble printing.
I keep getting the pop-up which says "Cannot find default printer."
I have been working with Mark but we have not been able to resolve this bug.
Is there any member out there who has experience with this same problem?
Any comment or suggestion would be appreciated.
Maury56
Maury56
Postby Mark » Mon Jul 11, 2011 7:29 pm
Hi Maury,
Did you get a chance to call the makers of Crossover to see if they could help?
Postby Maury56 » Mon Jul 11, 2011 8:22 pm
You cannot call them without an account and mine has expired.
I just spent $40 to renew for 6 months. Seems expensive but I want to get FM working properly and I guess this is just part of the price.
As a member now I get to nominate 5 software packages for them to work on. I just nominated FM.
It seems to me you would have an interest in this since if it was on their supported list, you could then refer MAC possible customers to their site. They will accept your money to help convince them to code the program so it runs perfectly under CrossOver. Might be something you should look into. Should be a LOT cheaper than actually having FM coded for MAC. Right now, FM is rated as BROZE. You want to get FM up to GOLD.
Anyway now that I am a supported member, I will start to work getting the support I need. Hopefully I can get this resolved before I go on trip Wednesday for 5 days. Good talking with you today. Thanks for GREAT FM support.
Maury56
Postby Maury56 » Mon Jul 11, 2011 9:20 pm
I just entered a trouble ticket with CodeWeavers.
We'll see how responsive they are.
Maury56
Postby Mark » Mon Jul 11, 2011 9:59 pm
Hi Maury,
Thanks for the update. Hopefully they can resolve that problem quickly. It will be interesting to hear the outcome.
