License Key
Postby reddragon » Tue Jul 19, 2011 7:31 am
Purchased the software Friday and the key that was sent to me is not working. Where do I get help at?
reddragon
Postby Mark » Tue Jul 19, 2011 8:45 am
Hi reddragon,
Sorry about the troubles. Please e-mail us by going to the form at:
Here are some common problems with getting your license entered:
http://www.fundmanagersoftware.com/faq_ ... icense.php
Postby reddragon » Tue Jul 19, 2011 1:26 pm
I downloaded the sample advisor software and then I purchased it. I do not see which problem it could be from the web site. Can not get in.
reddragon
Postby reddragon » Tue Jul 19, 2011 1:29 pm
O.K. I see I down loaded advisor 10.9 and you sent me a key for 11.0. Could that be it and if so in the sample acct I have several down loads of accts I had to manually enter I would like to keep. How do I accomplish this?
reddragon
Postby Mark » Tue Jul 19, 2011 7:12 pm
Hi reddragon,
I would suggest to just download the current version (11.2) from our website. Just install it right over your current 10.9 version. Do not uninstall 10.9 first. All your data will still be available in 11.2 once you install the new version.
If you prefer to stick with 10.9 we can send you a 10.x license key, but it is probably better to upgrade your software to 11.2. The download page is here:
http://www.fundmanagersoftware.com/download.html
Postby reddragon » Wed Jul 20, 2011 10:34 am
reddragon
