report order
Hi Normnip,
The default sort order for a new report listed by investment is the investment stack order. You can order this global investment stack however you want. You can also order the investment stack alphabetically by name if you use "Investments / Sort By / Name". You can also choose to sort your report by something else by just selecting it from the top level "Sort" menu. By default, you will see "Sort / Investment Stack" checked, but you can select any other column to sort by.
Hi Normnip,
The sort menu is found within the report. Run a report on your screen, the look at the very top of the screen, which is where you will see File Edit View Graphs Reports Options Sort Investments Window Help. Click on Sort and you will see which fields (columns) you can sort on.
