Create a portfolio of index components
Postby dlapish » Tue Aug 09, 2011 4:12 am
Is there a quick way to create a portfolio of the component companies of a specific index, such as the FTSE 100 or S&P 500? Obviously to create such a portfolio manually would be very time consuming so I wondered if you or any other poster had already found a way to do this which I could replicate.
Many thanks as always.
David
dlapish
Postby Mark » Tue Aug 09, 2011 10:15 am
Hi David,
Sorry, I don't know of a shortcut way to do this, other than manually create all these investments.
Postby dlapish » Tue Aug 09, 2011 1:14 pm
OK thanks, that's clear.
The reason for asking was that I would like to track the peformance of each constituent company of an index over a period of time. Yahoo Finance shows the constituents and their prices on any particular day, but does not allow you to download them (unlike the history of individual stocks).
I was thinking that maybe there was such a thing as a file or folder, like a template, which contained one share of each constituent company and which I could import or copy.
If anyone knows how I can achieve my objective and download the historical prices of index constituents as a group (preferably into Excel) please let me know.
Many thanks,
David
dlapish
Postby StarBright2011 » Wed Aug 10, 2011 6:07 am
David,
http://www.barchart.com/ has that feature.
I created a little video to demonstrate:
http://screencast.com/t/tU5mFVk9yuon
If the video doesn't show the steps clearly, I will documnent the steps.
Ernest
User avatar
StarBright2011
Postby dlapish » Wed Aug 10, 2011 8:23 am
Thank you for that, Starbright. The video works fine, I will have a better look at it later on. Do you know if the site has UK stocks as well, eg FTSE 100?
David
dlapish
Postby StarBright2011 » Wed Aug 10, 2011 8:59 am
David,
It does have quote for FTSE, symbol $FTSE; however, I don't find where it lists the components.
Ernest
User avatar
StarBright2011
Postby StarBright2011 » Wed Aug 10, 2011 9:08 am
David,
I did find a site that provides a spreadsheet download of the components of the FTSE. I don't know the acuracy of the data.
It lists five components and after the 5th is the link for the download.:
http://topforeignstocks.com/2011/06/16/components-of-ftse-multinationals-index/
Ernest
User avatar
StarBright2011
Postby dlapish » Wed Aug 24, 2011 12:25 pm
Ernest,
Thanks for that tip. In the end I decided to grab the data into Excel from the Yahoo web page. It takes a bit of work to get it set up but it is good enough for my purposes.
David
dlapish
