Forum Software update
Postby davcbr » Sun Aug 14, 2011 6:55 am
Just read your posting about being able to attach documents.
Your suggestion to use "Print Screen" will do just that. The entire screen - which is useful sometimes. I would add to this that holding down the "alt" key when pressing "PrintScreen" will copy only the current window, which is usually more useful.
davcbr
Postby aviator » Sun Aug 14, 2011 8:17 am
I use a product called Screenpresso which works well for me. It allows selection of just a portion of the screen if you don't want to capture the whole thing.
They have free and paid versions. The free version has all I need. You can find it here:
http://www.screenpresso.com/
Postby Ivan » Sun Aug 14, 2011 3:54 pm
If you have Windows 7, there is an applet in the Accessories Folder called Snipping Tool which allows you to capture any rectangular area of the screen and save as a JPEG. No need to load any extra software.
Ivan
