Mark:
Is there a way to serarate a mster portfolioss sub portfolios into completely separate files? I want to be able to run FM for specific portfolios without other portfolios available.
Separating Portfolios into different files
Hi jnewton,
Yes, you can copy/paste sub-portfolios across portfolio files. I'm curious why you would want to do this though? If you want to separate a sub-portfolio, just create a separate sub-portfolio hierarchy for it in your one portfolio file. It is usually best to just have a single portfolio file. It makes managing and updating your data easier. For a tutorial on combining multiple portfolio files into one, see: http://www.fundmanagersoftware.com/tuto ... video.html What you're describing would be similar, but opposite.
I want to separate several personal portfolio from a group of managed portfolios. Managed portfolios could be accessed by others, personal portfolio to be accessed by me. I understand it would entail dual updates etc.
Just trying to think it through.
Hi jnewton,
You can create as much hierarchy as you need. So, if you have some information that you want to separate out, create another layer of sub-portfolio hierarchy, like this:
Then, you can report on any level in this hierarchy, and only have 1 portfolio file to manage.
Thanks Mark.
We are going in similiar directions. I think I want to be able to manage the file as a master file, but be able to copy sub-portfolios for others to view/manipulate either on another computer or under another user name. They might get a file weekly or monthly that has their specific sub-portfolio on it thet they can load, view, and update. So how would you save a specific sub-portfolio to its own separate file? does the "Save Portfolio As ...." Command refer to specific portfoliosor only to the Master Portfolio?
Hi jnewton,
The "Save Portfolio As..." re-saves the whole set of all sub-portfolios open at the time. To save just one sub-portfolio, do this: 1) Select the sub-portfolio in the Portfolio Editor, and choose "Edit / Copy". 2) Close everything using "File / Close Portfolio". 3) Use "Edit / Paste" to paste the previous sub-portfolio into a new/empty Master Portfolio. 4) Use "File / Save Portfolio As..." to save this new portfolio file.
