importing symbols
Postby hokie63k » Fri Aug 19, 2011 4:24 pm
I have imported investments from MSM in QIF. It appears that the stock symbols did not import. Should they have?
hokie63k
Postby Mark » Fri Aug 19, 2011 4:45 pm
Hi hokie63k,
The QIF standard uses "Names" in the transaction section. The QIF standard also supports a "Security" section that maps these names to symbols. If your QIF file has this security section, Fund Manager will import it. It sounds like yours did not... You can manually edit the symbols under "Investment Properties... / General".
Postby hokie63k » Sat Aug 20, 2011 11:09 am
I exported from MS Money to a QIF file using MSM export command. Should it have had the security file so that I could get symbols?
hokie63k
Postby Mark » Sat Aug 20, 2011 11:18 am
Hi hokie63k,
I'm not sure, MS Money may only be exporting the transactions. You can open up your .QIF file in Notepad, and see if you see a security section, where it shows the symbols of your investments.
