Fund Manager on the WEB problem
Postby nebfinfm » Fri Oct 21, 2011 5:04 am
I have problem getting to "Tutorial, FAQ, Message Board and FM Home Page" on the Help - Fund Manager on the WEB. When I click on any above link I get message "There is no application associated with the given filename extension" Clicking on "Check for updates" works okay. What is the problem. Please reply to my email.
Thanks nebfinfm
nebfinfm
Postby Mark » Fri Oct 21, 2011 6:29 am
Hi nebfinfm,
It sounds like you do not have an association in Windows for the .html file extension. If you're using Vista or Windows 7, go to "Start / Control Panel / Programs / Default Programs / Associate a file type or protocol with a program". You should see a long list of "Extensions" and a shorter list of "Protocols". Make sure you have the extension of .html associated with your web browser, and the protocol of HTTP also associated with your web browser.
