Symbol change
Mark, I see no way to make a symbol change when one occurs across the db. Again, the nature of FM's db is the problem If there are 30 client subportfolios holding a security and its symbol changes, there should be a way to make that change universally. So far as I can tell, it has to be laboriously done on a subportfolio by subportfolio basis. Any thoughts?
Hi Mike,
You're right on this. This is something that I hope will be addressed in 9.0 to make this easier.
If a "major" release (i.e. Ver9) is being thought off, could you PLEASE consider a request to put in a method for reconciling accounts based on a paper statement. I was very pleasantly surprised when, after my switch to Quicken (yecch!), I found that they do exactly what I would like to see: once you have all the transactions downloaded, you enter the current balance from the paper statement, tick off the transactions that match and ...... away you go. Several of the retirement accounts do not have a facility to get an electronic file that once can reconcile against and so I would really like to see this being part of Fund Manager. I suppose the Quicken implementation is pretty much the template. thanks sj
Hi surendar,
Thanks much for the idea/feedback. For paper statement reconciliation, I usually suggest to use a Portfolio Value report, sorted the same as your statement, and just compare all the share balances. This seems like less work than manually typing in all your share balances to compare against? Am I overlooking something, or are there other benefits to typing in your share balances for reconciliation?
Thanks for the note. I should explain better ... I do use the Portfolio Report to make sure that the amounts (individual as well as total) match. This is something I do after I either 1) electronically retrieve the transactions and positions when possible (e.g. my broker), or 2) entering things by hand in the 401-k accounts that do not have any electronic updating capability In *either* case, what I would like to see is the ability to get Fund Manger to acknowledge that you have done the reconciliation and update the date of reconciliation. This is why I suggest the Quicken (or, for that matter, my old Managing Your Money) method, where you can tell the software that you have done the reconciliation and that it should be recorded as such. Right now, for example, FM says that the 401-k accounts have never been reconciled even though I do the cross checking every quarter as you suggest. I am *not* advocating typing in anything other than the total balance in your account (not individual ones) and the date of the statement and then hit the "Reconcile" button. Provided that the amount entered matches FM's portfolio value as of that date, one is done. Manually entering all transactions is needed only for those accounts which do not allow electronic retrieval of transactions -- like some of my 401-k accounts. But, after entering the transaction data and updating the prices, one is still left with the need to *record* the reconciliation. Allowing to record reconciliation against a paper statement covers all four possibilities. Hope this is clearer. thanks sj
I did make an error when I said: > I am *not* advocating typing in anything other than the total balance > in your account (not individual ones) and the date of the statement > and then hit the "Reconcile" button. Provided that the amount entered > matches FM's portfolio value as of that date, one is done. Actually, you would also have to check off which of the FM transactions and positions actually occur in your statement. One can expect some activity in the account to have occurred before the statement arrives (and one gets to sit down and do the reconciliation!). Again, note that I am not advocating typing in everything all over. One checking off the FM view of the account against the paper statement. This capability already exists in FM as the transaction history is shown after an electronic retrieval and one can (as I do) choose the ones you need to keep to match the statement. The missing bit now, is the recording of the fact the one has manually checked FM's balances against the paper statement and the date of the statement. thanks sj
Hi surendar,
Thanks for the clarification, I do understand the desire to be able to set/update the reconciliation date when you've done it manually.
Who is onlineUsers browsing this forum: No registered users and 6 guests |
