MSSB Online
Postby taxableted » Mon Jun 11, 2012 6:28 am
Hello,
When I try to set up my Morgan Stanley Smith Barney account, I get a message that my account has been moved to MSSB Online, which is correct, but I cannot see it as an option in a list of brokerages for transaction/position retrieval. Are there plans to add MSSB Online or am I doing something wrong?
taxableted
taxableted
Postby Mark » Mon Jun 11, 2012 8:26 am
Hi taxableted,
Do you maybe need to just update your account number? Try using the broker:
and just update your sub-portfolio's property of "account number" to your new account number.
Postby taxableted » Mon Jun 11, 2012 8:37 am
Mark, thanks for the quick reply. I just downloaded the trial version and am having trouble setting up/ linking this portfolio I have at MSSB. I am entering new account numbers. I just tried again and was told that I reached my retry limit and that my account has been blocked. Any other ideas?
Thanks!
taxableted
Postby taxableted » Mon Jun 11, 2012 8:41 am
fyi... just tried again and the retry limit is off, but I still get the message:
"General Error
Your accounts have been converted to MSSB Online"
I press "ok" (the only option) and get:
"Failed to receive portfolio.
Broker: Morgan Stanley Smith Barney
Account: !$%#%
User ID: 2@$%@^
taxableted
Postby Mark » Mon Jun 11, 2012 8:47 am
Hi taxableted,
If you log into their website, do they have instructions for retrieving into Quicken? If so, what is the name of the broker they say to choose for retrieval? You should be able to use the same instructions with Fund Manager.
Postby Mark » Mon Jun 11, 2012 8:58 am
Hi taxableted,
I found some instructions made by MSSB for using Quicken, and it looks like for MSSB Online you need to choose our server labelled:
Morgan Stanley ClientServ Investments
and use your 9 digit account number.
Postby taxableted » Mon Jun 11, 2012 2:57 pm
Mark, thanks a lot. I think it worked although not sure the right data is being downloaded or that I'm doing everything correctly. But it does connect and I hope I can figure this out. Just starting out to use the software )
taxableted
Postby Mark » Mon Jun 11, 2012 5:26 pm
Hi taxableted,
Glad it is retrieving now... If you run into any other questions getting started, just let us know.
