License
Postby wizard348 » Fri Jul 27, 2012 2:05 pm
I have Version 9, Personel. All of a sudden after at least a year of use, it is asking for my license again, I copied and pasted out of the email I received from you and it says invalid license.
Help. Please Hurry.
Gary D. Inman
wizard348
Postby Mark » Fri Jul 27, 2012 2:21 pm
Hi Gary,
Our records indicate you are licensed for the 10.x Personal versions. If you are using a 9.x version, make sure you are entering a 9.x license into the program. A 10.x license will not work when entered into a 9.x version. I've just now re-sent your current 10.x license key to you by email. If you need to download any older version, they are available here:
http://www.fundmanagersoftware.com/modlist.html
