Find an investment in Portfolio
Postby Flijfi » Tue Oct 23, 2012 4:01 pm
I would like to find an investment hold in my portfolio searching by either CUSIP, SYMBOL or NAME.
How may I do it?
PS: If possible I would like to extend my search to sub-portfolios.
Thanks!
Flijfi
Postby Mark » Tue Oct 23, 2012 4:05 pm
Hi Flijfi,
Create a Custom report with whatever field you want to search for, and then use the "Sort" menu to sort the report. You can run the report at any sub-portfolio level, and turn off sub-totals.
Postby Flijfi » Tue Oct 23, 2012 5:12 pm
Thanks.!
Flijfi
Postby Flijfi » Tue Oct 23, 2012 6:01 pm
Sorry for coming back on this issue, but I still need some help.
There is any way to search based on a substring or wilcard?
I have a lot of manual price updates and transactions and find the asset is painful in portfolios with about a hundred of investments so I am looking for a way to find them.
Or even a more complex search where may I find a substring (like company name) name in the description AND a currency=XXX or any other logical combination of asset properties.
Any way to accomplish that?
Flijfi
Postby Mark » Wed Oct 24, 2012 7:17 am
Hi Flijfi,
Sorry, there is no "investment search" feature like this. There is a search feature for a sub-portfolio in the Advisor version, but not for an investment. You would want to use one of the sorting features to sort by a field that can help you find the investment. You can sort any report by using the Sort menu, or you can sort in the Portfolio Editor list view by clicking on any column's header.
Postby Flijfi » Wed Oct 24, 2012 9:11 am
You may consider it as a RFE for next version?
Thanks again!
Flijfi
Postby Mark » Wed Oct 24, 2012 9:16 am
Hi Flijfi,
Okay, will do. Thanks for the idea.
