Copying portfolio to another computer
Postby moonlighter » Sun Dec 23, 2012 2:31 pm
I successfully copied all my portfolio files (portfolio and investment files) but the changes I made to the columns on one computer did not transfer to the other computer. Anyone know where is the file stored that saves the column settings?
moonlighter
Postby Mark » Sun Dec 23, 2012 6:05 pm
Hi moonlighter,
Your preferences such as memorized reports are stored in the registry. If you use the backup/restore feature in Fund Manager is will transfer these registry preferences for you. If you'd like to manually transfer, you can use regedit to export/import this key:
HKEY_CURRENT_USER\Software\Beiley Software\Fund Manager
Postby moonlighter » Sun Dec 23, 2012 7:13 pm
Great, used backup/restore function to set columns the same on both computers. This is working very well. Thanks!
moonlighter
