Error :126
Postby Segunmichael » Thu Jan 24, 2013 1:41 pm
Please the error message Error : 126 always come up regularly on the FM software especially when trying to update stock prices. Please what does this mean.
The sequence of error messages are:
>Error: 126
>The specified module could not be found.
>Could not load TRANRETR.DLL
Make sure it is located in the same directory as the fm.executable file.
Segunmichael
Postby Mark » Thu Jan 24, 2013 1:58 pm
Hi Segunmichael,
I'm not sure what error 126 is? Is that all it says? If you do a "Help / FM on the Web / Check for Updates..." are you able to get the quote and transaction modules updated okay?
What version of Fund Manager are you using?
Postby Segunmichael » Thu Jan 24, 2013 2:20 pm
Thanks for the quick response. How do i check for the version of my FM? What do you mean by quote and transaction modules please? I am scared of checking for updates for fear of loosing my portfolio. I lost one today after saving, as the saved version wont open. I had to restore a previous back-up version.
Thank you.
Segunmichael
Postby Mark » Thu Jan 24, 2013 2:23 pm
Hi Segunmichael,
You can find your version number under "Help / About...". That error message is indicating that you're missing the transaction retrieve module. You can re-download the latest transaction retrieve module by selecting "Help / FM on the Web / Check for Updates...". This should have no impact on your current data.
Postby Segunmichael » Thu Jan 24, 2013 3:18 pm
My FM is Advisor Version: 12.0, Quote mode: 440 and Transaction module: 0.
Segunmichael
Postby Mark » Thu Jan 24, 2013 3:22 pm
Hi Segunmichael,
You need to download the transaction module. It is missing for some reason. You can either use "Help / FM on the Web / Check for Updates..." and allow it to download updates when prompted, or you can re-install the whole program, by going to our download page:
http://www.fundmanagersoftware.com/download.html
Postby Segunmichael » Thu Jan 24, 2013 3:25 pm
You were right. After updating my Transaction module as advised, the error message stopped popping up. It now updates prices easily. Thanks
Segunmichael
