Can I use 2 pc's with my licence ?
Postby gbfabiani » Fri Mar 15, 2013 4:56 pm
Hi , I have a portfolio on Dropbox, and I was used to acess it with both my laptop and my desktop, using the same licence ( That was with 11). Now with v 12 it looks like I can't register more that one PC . Is it like that ?
thanks
giovanni
gbfabiani
Postby Mark » Fri Mar 15, 2013 5:45 pm
Hi giovanni,
The license terms have not changed. You can use your same license key on up to 3 computers for your own use. What specifically is happening when you try to enter your license on your 2nd PC? Please make sure you are entering all 3 fields exactly as provided, and that you are entering them into the version you are licensed for.
Postby gbfabiani » Fri Mar 15, 2013 10:31 pm
It tells me I have entered an invalid license code.
I know I made experiments in he past, such as loading Fundmanagersoftware on a windows virtual machine on a mac (with parallel) . He did work fine, but at the end I didn't use. It looks like I have the license used on a cpuple of PC I am not using anymore, how can I clean them, it is enough if I remove the software , or an option "release license " is available somewhere ?
I ask it, as I don't run parallel/windows on this Mac anymore, so it could be complicate to recreate the environment just to cancel a program !
thanks
gbfabiani
Postby Mark » Sat Mar 16, 2013 11:48 am
Hi gbfabiani,
Please check your email. I've just now emailed you your license key, along with some tips for entering it. Please let us know if you are still unable to get your program licensed.
