error installing update
Postby robbieh » Mon Aug 26, 2013 9:13 pm
I am trying ot install to a flash drive but run into a problem when the installer is extracting the sample files (dell.dat specifically). It seems to drop these files in the 'documents' folder (not on my flash drive). For me the documents folks is a redirected folder and this seems ot upset the installer. Is it possible to have the installer push these to the flash drive (and thus be self contained on the flash drive)?
robbieh
Postby Mark » Tue Aug 27, 2013 8:37 am
Hi robbieh,
The installer will install the Samples into the folder:
<My Documents> \ Fund Manager \ Samples
Do you maybe have a Dell.dat file in there already that is marked as read-only or something? You can't change the location where the samples are installed. You can ignore these errors when installing. The samples aren't required to run the program.
