by Mark » Tue Oct 08, 2013 9:18 am
Hi Zix,
To change, right mouse click on an investment, and choose "Properties...". In the Investment Properties dialog, select the "Asset Type" tab. Select the asset type you want it to be from the list, and then press "Change %". Set it to 100% and press OK. Now, you will have 2 asset types set to 100%, so go hilight the one you do not want and change it to 0% so that the total % reads 100%. Press OK or Apply to this dialog.
You can also customize the labels of all the asset types. It is best to do this before assigning all your investments. You can do this under "Options / Category Labels...".
