Expense Ratio Reports
Postby Cole » Wed Nov 27, 2013 1:52 pm
I'm needing a report that can break down the dollar amount paid for owning a mutual fund or ETF. Is there a way to enter in a mutual fund or ETF expense ratio for individual investments? Can a report then use that entered expense ratio to calculate the amount paid in dollars for that particular investment? Lastly, is there a way using the entered expense ratios to calculate the total dollar amount paid in expense ratio's for entire portfolio?
Thank you,
Cole
Cole
Postby Mark » Wed Nov 27, 2013 2:04 pm
Hi Cole,
You can do this by using one of the custom investment properties. First, go to "Options / Custom Investment Properties..." and define one of the available custom fields to a name of:
Expense Ratio
with a type of "Number" and a "Combination Method" of "Weighted Average" and decimals "2". Now, go to each of your investments, and under "Investment Properties... / Custom" enter the expense ratio for each investment. For example, if the expense ratio is 0.75%, enter 0.75.
You can then report on the expense ratio in either the Portfolio Editor, or a Custom report. To get this into a value based number in a Custom report, define a user-defined field with the equation:
ExpenseRatio*End_value/100
The "User-Defined..." button is in the bottom/left of the "Custom Settings" dialog where you choose which fields to add to your Custom report. This user-defined field feature is available in the Professional and Advisor versions, but not the Personal version.
Postby Cole » Thu Nov 28, 2013 8:27 am
Thank you, exactly what I needed.
Cole
Postby aviator » Thu Nov 28, 2013 8:31 am
Hi Mark and Cole,
This was a very useful tip, something I've needed for a while but never considered using the method Mark suggested.
Mark, maybe you can add a "tips and tricks" section to the board for items such as this.
And Happy Thanksgiving to all!
Postby Mark » Thu Nov 28, 2013 9:42 am
Hi aviator,
Thanks for the feedback. From the main FAQ page there is a link to Helpful Tips. I've just added this as a new tip on that page. See it at:
http://www.fundmanagersoftware.com/expense_ratio.php
