Unable to find portfolio
Postby ddnut » Thu Jan 16, 2014 7:31 am
I manually entered a sample portfolio using tranaction reports from my brokerage yesterday but today I could not find the portfolio. I was looking for the files and found the .DAT files and the transactions appear to be OK.
In the process I opened one of the .MM4 files in the sample folders so my Master Portfolio now shows those subportfolios. When I open the Investment files I created, they get brought into the current Master Portfolio (samples).
It is not too much data and I can start over but I don't know what happened or how to fix it.
Duncan
ddnut
Postby Mark » Thu Jan 16, 2014 5:03 pm
Hi Duncan,
It sounds like you maybe didn't save your portfolio file? Try this:
1) "File / Close Portfolio" to close everything open.
2) "File / Open Investment(s)..." and open the investment files you created.
3) "File / Save Portfolio As..." and give it a filename. Now you have a portfolio file with the investments you previously created.
Postby ddnut » Thu Jan 16, 2014 6:16 pm
That is probably what happened, the Save Portfolio on Exit option was not checked and I was not paying attention when I closed the program.
Thanks for the tip on selecting all the Investments at once - that did not occur to me.
ddnut
