Hello,
i'm searching for a way to return at the previous version of fund manager.
I don't know how I can convert files .fmb beta version 2014 in files .dat of preceding fund manager.
Thank you.
convert file .fmb (version 2014 beta) to file .dat
Hi Seboz,
Any investment (*.dat) or backup (*.fmb) files created with the FM 2014 cannot be used with earlier versions. You would need to have a backup from that earlier version. Hopefully you created a backup file with your old version before installing the new version? If not, you might also check your autoback folder for a *.fmb file that was created before you installed FM 2014. If you find a *.fmb backup file created with your old version, just use "File / Restore..." and select that backup file to restore your old data.
Who is onlineUsers browsing this forum: No registered users and 4 guests |
