Conflicted Copies
Postby johnreid » Fri May 23, 2014 7:32 pm
I have just noticed quite a number of my data comes with the comment that there is a "conflicted copy". It reads "xxxxx yyyy;s conflicted copy 17/05/14". It will be followed by a good copy of the file but with a different date.
What causes this? And do I have a probem? I am rulling 11.7
John Reid
johnreid
Postby Mark » Sat May 24, 2014 10:20 am
Hi John,
I don't believe this is being caused by Fund Manager. Are you maybe backing up those files with some other program? I did a quick Google search, and this term sounds like something from Dropbox. Do you have your files stored in a dropbox folder? See:
https://www.dropbox.com/help/36/en
Postby johnreid » Sun May 25, 2014 5:27 pm
Thanks - that seems to be the problem.
Johnreid
johnreid
