Hi.
I am testing out FM and ran into a problem with exchange rate entry.
Initially I downloaded an earlier version, but after reviewing postings i went back and installed 2014.13.2
The same problem is encountered. My default currency is CAD.
Under Options/Currency Settings, I see no option for transaction specific exchange
Mark said talking to Milli:
What version of Fund Manager are you using? In the current version you can specify transaction specific exchange rates. When an investment is assigned to the non-default currency, and you enter a transaction, there is a check-box in the lower/left called "Specify Exchange Rate to Default:". If you check that, you can then type in the exchange rate to be used for that transaction. This is independent of your global exchange rate settings.
When I enter a transaction in USD I also see no option to specify transaction specific rate.
I cannot paste a screen capture of this dialog box.
I need to enter the exchange rate iTrade charges me for each trade, as I discover in communication with them they may charge a rate higher than end of day, or the rate specific to the time of the trade execution.
John
