by fundman247 » Thu Jul 17, 2014 3:10 pm
Thanks for the response.
I only use about 10 fields but some columns are manipulated on a regular basis and those are the File name, Description, Account number, Symbol and they cause the waiting period.
These columns are normally small but need to be opened up to see the contents.
I see if one actually sorts any field there is no re-calculation. The sorting is the function I use more than opening up the columns. I find it easier to sort any column in the Portfolio Editor than using custom reports.
Regards.
Remeber and practise it!!!!!!
