All of my Asset Labels have disappeared. The standard ones are there, but all of my user defined labels are gone.
Can this be fixed??
Asset Labels
Hi gcm223,
If you are not running in "portable/cloud" mode all these Asset Type labels are stored in the registry. You can use "File / Restore..." and restore from a recent *.FMB backup file. You can check on your automatic backup settings (to find the location of your *.FMB automatic backups) under "Options / General Preferences... / Data". When you do the restore, you would only need to select the "Global Preferences (registry values)" and choose to only restore selected items, instead of everything in the backup.
Who is onlineUsers browsing this forum: No registered users and 28 guests |
