loading my portfolio on start up not sample portfolio
Postby rkfrost » Thu Aug 07, 2014 1:00 am
When I open fund manager it always opens the sample portfolio how do I get the program to open my portfolio which is in a different directory
The open last portfolio option does not seem to work
I want to get rid of the sample portfolio
rkfrost
Postby Mark » Thu Aug 07, 2014 7:20 am
Hi rkfrost,
Are you maybe starting Fund Manager by using a shortcut that is pointing to the sample portfolio file? Try starting Fund Manager with the shortcut under "Start / All Programs / Fund Manager / Fund Manager". You can verify the properties of the shortcut, and it should be pointing to the program (Fm.exe), and not a shortcut to any particular *.mm4 file.
Portfolio files will have the same icon as the main program, and by double clicking on a portfolio file, you will open up that portfolio file. Instead, you want to open up the main program, without specifying a portfolio file, and it will then automatically reload your last portfolio file.
Postby rkfrost » Thu Aug 07, 2014 12:36 pm
Thanks problem solved
rkfrost
