Div Yield on Cost
Postby sponge » Fri Aug 29, 2014 12:30 pm
Is there a way to get Dividend yield on average cost basis?
sponge
Postby Mark » Fri Aug 29, 2014 12:57 pm
Hi sponge,
Not from any built-in field, but you could probably write a user-defined field equation to calculate what you want. If you're using Professional or Advisor, see the "Define Fields..." button in the Custom Settings dialog.
Postby sponge » Fri Aug 29, 2014 1:17 pm
Unfortunately I am using Personal version
sponge
