I got a msg to e-mail a dump file to you after a crash in FM.
I have mailed it to you for ur attention.
Regards.
fundman247
dump file from FM 13.1
• Page 1 of 2 • 1, 2
I got a msg to e-mail a dump file to you after a crash in FM. I have mailed it to you for ur attention. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
However beautiful the strategy, you should occcasionally look at the results - Winston Churchill Remeber and practise it!!!!!!
Hi fundman247,
The latest version is 2014.13.4. Please download that, and let us know if the problem persists. The issue may have already been fixed. Here is the download page: https://www.fundmanagersoftware.com/download.html
Thanks Mark. I will install the latest version.
Regards. Don't stay in bed....unless you can make money in bed - George Burns
After I installed the latest version I still get the same crash report as before. The crash is when I run a custom report that has 6 settings and all the settings relate to %Gain 3m, 6m, 12m, 36m, 60m and 120m. If I run the same custom report on a much smaller portfolio all works well without crashing. It seems it does not like to run on a big portfolio with lots of investments. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
Hi fundman247,
Can you email us the crash (*.dmp) file you received with 13.4? These dmp files are version specific.
I have e-mailed you the *.dmp file for version 13.4. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
Thank you. I replied with a question about sharing your data. Please let me know...
I have replied on ur e-mail.
I tried to reduce the investments by closing about 130 of the 498 investments but found it still crashes. I then added the 130 investments back and removed 170 from another sub portfolio and found it then does not crash. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
E-mails on their way. I have sent the zip file via gmail and some files split up for you to combine via my normal e-mail. Due to the size it is very slow to upload. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
Hi fundman247,
Thanks for all your help. We were able to find/fix this issue. It will be fixed in the next release (13.5). If you would like a pre-release of 13.5 with this fix, you can send us an email.
Thanks for pointing to a corrupt .dat file. What I found strange the problematic file with the one date a price of zero could not be edited in FM then it crashed. At another instance I recorder a new price for the same date and the data stack showed the zero price as well as the newly added price for a date in 1998.
Lastly I found the corruption so bad that FM cannot open the file and crashes the moment one tries to open it. After removing this file the report is working 100%. As this is a isolated problem on a bad .dat file you don't need to inform me when the beta version is available. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
Hello Mark,
I have the same problem as before. This time it must be a different file causing the crash. I have e-mail you a zip file as well as the dump file caused by the crash. Please help in identifying the file causing the crash. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
Hi fundman247,
This is indeed the same problem you reported before. I have sent you a pre-release of 13.5 by email which should resolve this issue.
I will let you know after I replaced my fm.exe later in the day. Thanks a lot for the support. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
Hello Mark,
The problem has been solved with the latest version you e-mailed me. Thanks a lot. Regards. fundman247 Don't stay in bed....unless you can make money in bed - George Burns
Who is onlineUsers browsing this forum: No registered users and 14 guests |
