How to update software version
I find that I am using the software Version 2014.13.3 while as per the website the latest is Version 2014.13.4, when I clicked check for updates in the software it is not downloading the latest version. Perhaps it is checking only for the transaction and price modules. Will it be possible to update the software as well through this method. This will help avoiding downloading the version updates every time and over writing the existing installation.
Hi SHAREVJ,
Thanks for the feedback. Yes, this is possible, and something we can consider. For now, the "Help / FM on the Web / Check for Updates..." command only updates the quote and transaction modules. If the main program has a new version you must go to the website and download/install the program. You can just install the new version right over the old. Do not uninstall the current version. The download page is here: https://www.fundmanagersoftware.com/download.html
Hello Mark,
I did manual install over the old version and it is working well. Thank you. Please consider auto update in future. Of course, if it is a major revision where one has to upgrade the software, you can prompt them to purchase page as well.
Who is onlineUsers browsing this forum: No registered users and 14 guests |
