Evaluate Professional version if Personal already loaded?
Postby Jim » Mon Feb 16, 2015 9:16 am
Hi..is there an easy way to test the Professional version if I've already been evaluating the Personal version (and haven't yet purchased a license key)?
I do have quite a bit of data loaded into the Personal version that I'd like to test on the Pro version now that I'm more familiar with the capabilities of the software. I'm going to buy one or the other for sure as I've been really impressed with the features and how well written this is - but just am not sure if I want to purchase the Pro or Personal version.
Thx -
Jim
Jim
Postby Mark » Mon Feb 16, 2015 10:41 am
Hi Jim,
Yes, you can do this quite easily. Just install the Professional version right over your Personal version. All your same data is available. The data files are interchangeable between versions, so you can easily switch back/forth. If you decide you want to stick with Personal, just install that one back again.
