Error
Postby gerhardps » Thu Aug 14, 2008 11:36 am
I am getting the following error, it only occurs when updating prices.
could not create internet output log file 'c:\documents and settings\gary schneider\application data\fund manager\intlog2.txt'
check directory specifications in registry key
'hkey_current_user\
software\beiley software\fund manager\current version\directory location'
any help would be appreciated
thanks
gary
gerhardps
Postby Mark » Fri Aug 15, 2008 8:35 am
Hi Gary,
Fund Manager is trying to create a temporary working file at:
but is failing to do so. Usually this is because that file is marked as read-only or there is some other permission problem. Please use Windows Explorer and browse to that folder, and look at this file's properties. Note, the 'application data' folder is hidden, so you may need to turn on the option to view hidden files/folders. Make sure the file is not marked as read-only. If it is, just remove this property.
