Android App Testers Needed
Postby Mark » Fri Jun 19, 2015 9:47 am
We are currently developing an Android app as a companion app for Fund Manager. If anyone is interested in helping to test the app before release you can do so by joining the Google+ "Fund Manager Testers" community we've just set up for this by going here:
https://plus.google.com/communities/115 ... 5983198575
Postby SHAREVJ » Wed Jul 01, 2015 7:34 am
Hello Mark,
When I tried the link (https://play.google.com/apps/testing/co ... undmanager) , after my google login, Google play is showing the following error,
Sorry - nothing to see here.
There may be several reasons:
The app you’re looking for doesn't exist
or
the app developer is not currently running a test
or
you are not eligible to participate in the testing program.
If you received the link to this page from someone, we recommend you contact them for more information.
Please advice
SHAREVJ
Postby Mark » Wed Jul 01, 2015 9:13 am
Hi SHAREVJ,
Before you can access that page, you have to join the Google+ community with the same Google account that you'll be downloading the app with. Since the Fund Manager app is in Alpha testing, only people who belong to this Google+ community will have access. It is free to join by anyone, but you do have to join first. So, just go to this community:
and make sure you join it with your same Google account, and then you should be able to see it from:
Postby aviator » Mon Jul 06, 2015 7:11 am
Private message has been sent to you.
Postby Mark » Mon Jul 06, 2015 9:18 am
Hi Aviator,
Thanks, received, and replied.
Postby aviator » Mon Jul 06, 2015 9:29 am
Received, thanks for your prompt reply as usual.
Postby fundman247 » Thu Jul 09, 2015 12:32 pm
Look forward to the Android App. Only saw a bit late you were looking for people to help test the beta version.
Regards.
fundman247
Remeber and practise it!!!!!!
fundman247
