Data Register Data
Postby investor » Fri Aug 15, 2008 1:16 pm
Is there a way to see on the data register under the "distributions" category the amount of the distribution? I could have sworn I saw that in the past. thank you.
Chris
investor
Postby Mark » Fri Aug 15, 2008 1:55 pm
Hi Chris,
Yes, 'Value' is one of the columns listed there. If you don't see it, maybe you've re-ordered the columns, and it is off the screen to the right? Can you scroll horizontally? The other possibility is that this column is set to 0 width. Try clicking/dragging to widen it. By default it is the 4th column, after "Shrs Reinv".
